REMOVING 2001 XR6 OIL Injection System
CJEhlers
I'd like some info regarding getting rid of the oil injection system on a 2001 XR6 as I'm done trusting the system and would like to go with premix. Other than disconnecting the system lines, any other advise to send my direction would be greatly appreciated. As it looks, there is a splitter on the top of oil line coming into the reservoir on the top front of the motor and a line going into the bottom of the block for vacuum? Also, this small oil reservoir has a float on the top front of the motor, which I'm assuming, is attached to a horn. I was going to disconnect this as well, but do not want to disconnect the horn completely if I don't have to.
Any suggestion would be greatly appreciated.
gss036
Re: REMOVING 2001 XR6 OIL Injection System
Do a search from the bar across the top of the page and bring a cup of coffee to enjoy, there are dozens of posts addressing your question.
