Re: Remove stern drive?
No, Just in Forward Gear.......<br />This Aligns the Shifter Shoe in a straight line with the direction the outdrive has to slide Off.....<br />It can be seen by looking Up, from below the drive.....<br />In Neutral, or Reverse You'll be Bending things to get it off......<br /><br />In a nutshell...............<br />Move Shifter to Forward gear.......<br />Loosen the 2, 9/16ths nuts on the Forward end of the trim cyls....<br />Remove the 2, nuts holding the rear of the cyls,+ slide them free of the drive.......<br />Remove the 6, 5/8ths nuts holding the drive to the bellhousing........<br />Slide the drive Off.............<br />It weighs about 70lbs. or so.......<br />BTW, these are Wrench sizes, rather than the actual nut sizes(3/8s,+ 7/16s).......<br /><br />Good Luck.....
