Remove Powerhead 1989 28hp SPL e28eslcea
Honorary Supreme Mariner
The shift interlock is used on almost all these motor blocks from about 1980 to 2005 .-But not on the 28 hp economy models.----Not too many of those in my area .-Sorry for misleading you on that point.
Squawsher
Well thanks. Good to know Im not missing parts. At least not that part.
Still haven't managed to knock her loose as I'm not sure where I can whack or pull without breaking something but I have been spraying the seam between powerhead and midsection with penetrating oil in hopes that she'd come loose eventually.
Don't really just want to slap it all back together now but that might be what happens. It won't let go.
Any other ideas to get it free short of a crane and wrecking ball?
Thanks again.
Chinewalker
Leverage is your friend. Get a big, long flat blade screwdriver and wedge it between the base of the exhaust plate and the belly pan, about the 7:00 position if looking straight down on the motor, from the rear. Some good meat there, so you shouldn't break anything.
