remove outdrive housing from gimble ring
Flyer210
Need to remove a gimbel ring from the gimbel housing on a 82-83 mercrusier 228 HP. Instructions please. Everthing is loose.
f_inscreenname
Re: remove outdrive housing from gimble ring
If you are talking about the shaft that goes from the outdrive through the gimbel bearing into the coupler (bolted to the flywheel). It should have come out when you pulled thy outdrive. If not for whatever reason,give it a pull from the outdrive side.It may stick a little,its been in there for 20 years.
ODDD1
yes, flyer a special tool is needed....is an external 12 point to fit inside the 'hinge pins'..head for the mercruiser dealer...
Flyer210
So I go to a dealer and buy or borrow a 12 point<br />external socket. Does the hinge pin screw in <br />through the gimble bearing and gimble ring into<br />the upper housing? Standard right hand threads?<br />Sorry to bug you with all this detail.
Flyer210
Got a 12 point adapter and pulled the hinge pins.<br />Removed the upper outdrive housing. <br />Now I need to remove the two pins at 12:00 and<br />6:00 that hold the gimble ring in the housing.<br />Is the pin at the bottom screwed in or tapered?<br />If screwed in there's not much of a slot for<br />removal is there. Top pin, which is attached to<br />the steering arm appears to be pressed into the<br />gimbel ring. Is that correct?
