I was able to remove much (say 70%) of the duradecking on my boat by using a heat gun and scraper to lift the edges and peel the coating off. It is not fast, but the surface underneath is basically perfect afterward.
The only areas that don't appear to be cooperating are those on the bow where there was thin aluminum sheet, basically insulated with the foam flotation underneath where the duradecking was so baked-on it is crazed and it isn't strong enough to peel. The fact that it had been overpainted with BLACK paint didn't help this, I expect.
I have tried aircraft stripper on these stubborn areas, but it only seems to soften the 2 layers of paint, not the duradecking. I must admit, I didn't leave it on there for a long time, but I'm open to suggestions.
My boat had been drilled up a lot over the years - any good ways to fill in the holes and provide a smooth finish? I tried epoxy, but some has not hardened right, and other areas already cracked.
Thanks!
Thanks!
