TundraRocks
- Oct 18, 2009
- 134
I have a 70esl74m that has a water intake screen that has turned to mulch. I have the intake replacement part and have taken the LU off and the water pump off. In an attempt to remove the intake screen it is hitting the bearing housing
that sits below the water pump plate. I need to remove the housing but don't know what I'm getting into. I have a manual, but its removal states that it is one of the last components to removing the entire drive shaft.
That I don't want to do. If I remove the housing are there any seals that are going to need replaced? I have already removed the screws, and attempted to slide the housing up the shaft, but has not budged.
Below are a couple of photos...
Thanks for your help.
