i'm at a loss. i just worked for hours two days ago trying to repair a broken warm-up lever on the remote controls for a 85 30hp seahorse.
yesterday i spent hours taking a power pilot out of an old boat to use to replace mine.
today i spent hours and money wiring a new switch into the controls.
i finally got it on and installed in my boat and then when i was trying to synchronize everything the controls jammed and the warm-up lever seems to have broken on this box too.
it's a power pilot remote box. the warm-up lever doesn't seem to be doing anything on the inside when i take it apart.
here's a diagram i found:
part 23 looks like it has a bearing on the front of it that connects to the warmup lever? i don't see that anywhere and i didn't see it fall out. from the inside you can see the end of the screw down in the shaft that connects the warmup lever. on part 23 there is only a screw holding on the control cable arm. beside that is a hole that goes around the shaft that lever is screwed into.
does anyone have any idea what this problem might be?
please help. i've got to get my boat in the water.
