reliable mechanic in south fla???
Dhadley
Re: reliable mechanic in south fla???
Soryy - I just couldn't resist. <br /><br />What kind of OMC motor do you have? What is the problem with it? Where are you? Where have you been?<br /><br />Let us know and maybe we can get you headed in the right direction. So to speak.<br /><br />Good luck!
MakoMike
If my motor starts and runs tomorrow, I'll give you the name of the guy I'm using - See reference to postings at "225 evinrude starting problem" I'm in Venice FL and also interested in reliable references. Thanks.
wrat
well were to start?????? itsa 1996 johnson 150.. it was havin problems coming down off plane it would hit around 3500 r,s and start sputtrin coughin etc..so I took it to someone and they proceeded to really screw it up they seized the engine by runnin with the cowling and intake cover off and water was sucked into the carbs because of the original problem...then they decided to take to someone else ( I had no choice they were payin now)...well the 2nd guy supposedly rebuilt the engine I got it back and whammo the orginal problem is back only much worse sooooo what a nightmare im in West Palm beach btw
