Reliability of 1996 Johnson 35 HP
blindb9
Looking at buying a 14' fishing boat. Boat has a 35 Hp johnson motor (1996) with electric start. Picture attached seems like the motor is VERY clean. Doing some research on it and there is a lot of talk about the oil pump or something? Something making the engine die frequently, also stories of the power packs going bad often?
Im new to boats so I dont want to get stuck with a money pit for a motor...
Should i steer clear of this motor??
Thanks for any help...
HighTrim
Re: Reliability of 1996 Johnson 35 HP
It is a good motor, and looks clean.
However, if you dont want a money pit, dont buy any motor. You know what BOAT stands for, Break Out Another Thousand :)
Being proactive and doing the maintainance will limit the amount you spend on the motor.
Before you buy any motor, make sure you take it for a water test, AND check the compression.
blindb9
thanks hightrim, i realize any motor will eventually break and need repairs and maintenance, I just dont want to buy it if this motor has a bad reputation...
what about the VRO? lots of talk about that too when i research this motor, people disconnecting it, and motors imploding because of vro failure. Any thing to worry about?
thanks again
HighTrim
Well Im biased because I have had a VRO fail on me destructing the motor. I disconnect them, as I trust my premixing.
HOWEVER, there are thousands of motors with the VRO still connected running just fine. (Not a very good answer is it, sorry)
blindb9
would this motor have one?
like i said, im pretty new to this...
thanks
blindb9
the this is that i have another boat im looking at that has a mercury (2003) 25hp, I like the boat with the johnson better but i think the merc might be a better engine?
