Relay or slaves solenoid and no fire at coil
loonlaker
2005 four winds 3 L originally now 2014 3 L MerCruiser adaptive portion of wiring harness contains a relay around the starter but no slave solenoid engine turns over but no fire That coil I am checked out replacement coil test say OK
Ayuh,..... Welcome Aboard,..... It sounds like yer confusin' the Start circuit, with the Ignition circuit,.....
They're 2 very different circuits,....
There should be power at the coil's (+) tiny terminal, with the key in the "On" position,.....
If not, start testin' at the key-switch for power in the Ignition circuit, usually purple wires,....
loonlaker
Thanks 1 million going to get started on it right now let you know how things turn out
