Re: Reinstaling lower unit
Hi,<br /><br />I don't know about that specific motor (I have an older V6), and I don't know how close you are getting it to go together. When I've put my LU back on, its helped to have someone else around who can slowly turn the flywheel (by hand) as I'm trying to fit the driveshaft splines into the matching splines on the powerhead. Some say take the plugs out to make it easier, but I've never bothered, thumbs on flywheel has worked. Slowly move the flywheel a few degrees and then "magically" it slips into place when the spline align (hopefully). It's good to lightly grease the splines on the driveshaft before reassembly, but don't put any grease on the end of the driveshaft, or it'll take up space and you won't get it together (grease doesn't compress well).<br /><br />good luck.<br /><br />Brent
