BassScratcher
- Apr 29, 2002
- 43
I just purchased a 93 Mariner 200 EFI. I purchased a new starting battery. I noticed after the second time that I had the boat out, that the engine is not charging the battery. The volt meter is only reading 11 volts. The engine has 2 regulators and it looks like it is set up in a split output configuration (20 amps to starting battery and 20 amps to auxillary battery). I've determined by the wiring, that the upper regulator is used to charge the starting battery and the lower regulator is used to charge an auxillary battery. I connected an ohm meter between the 2 short yellow leads from the stator and received .5 ohms. I did the same test to the 2 long yellow leads from the stator and also received .5 ohms. According to the service manual, this is an acceptable reading. Does this eliminate the stator? I think the fault is in the upper regulator, because when I connect the leads to the battery (upper regulator), I do not get the normal spark. When I connect the leads (lower regulator), I do get the normal spark. What's baffling me though, is that the tach is connected to the upper regulator. Is it possible to have a bad regulator, but still get a tach reading? Any help would be appreciated.
