REGULATOR--70HP FORCE 1990
This is my second failed reg. in 2 years Maybe 20-30 hours .I have
knowledge of others with same problem
P/n 815279-2 Last part was 165 dollars. Does any one know of a way out of this delema? or a fix
Any help or ideas of this situation would be dearly welcomed.
Al Mc
First one failed with no output
Second one failed by discharging battery at a reading of 7ma
roscoe
Re: REGULATOR--70HP FORCE 1990
Never had a reg/rec problem with my '95 70hp Force that I had for 8 years.
Could have another component causing stress on the reg/rec.
Like a battery with a weak cell.
BTW, the 70 hp Force was made from 1991-1995.
harkawy
Check out Seilermarine
I purchased the rectifier for my Force 70 and it works great. By the way, if you have two batteries and a switch between them, make sure that the motor is off before changing between batteries (unless your switch is "make before break.") The rectifier must be attached to a battery while the motor is running or the rectifier will blow.
