Re: regular or super unleaded
This is all hearsay but I read somewhere that during storage ethanol gas can lose octane rating having something to do with ethanol having very high octane, and the octane rating of e-10 being an average of gas and ethanol's octane.
Yeah, it is "hearsay"
Actually older blends of (non-ethanol blends) gasoline (and winter grades etc) will "lose" octane when stored over long periods of time because the "higher ends" DO evaporate overtime. (summer gasolines are made with lower vapor pressure than "winter " gas)
The older blends did it more readily because the EPA allowed refiners to manufacture gasoline with higher vapor pressure "back then".
Over the last several years gasoline refiners have been mandated to make gasoline with lower vapor pressure to reduce evaporation (and reduce "evaporative-emissions")
Aviation gasoline for example, has ALWAYS been made with an RVP (Reid Vapor Pressure) of about 7psi. (this is because gasoline can actually boil at high altitudes causing vapor-lock and engine failure in aircraft)
RVP in Calif back in the early 1990's could be as high as 9psi.
It's now limited to around 7psi (
http://www.arb.ca.gov/fuels/gasoline/rvp/rvp.htm )
Low RVP gasoline can be a problem in carbureted engines because it doesn't vaporize as well as gas with a higher RVP. (it doesn't matter as much in in an EFI engine because you have a pressurized fuel injector to atomize the fuel)
None this matters anymore though since refiners are completely controlled by the EPA and for gas used in Calif, the EPA and CARB (California Air Resources Board)
Don't always assume that because the retail gas station "says" you're getting NON-oxygenated fuel that you're actually getting it! It may still contain ethanol!
If you want to be absolutely sure that you're getting gas without alcohol in it, you'll have to test it using one of the many kits available (to buy or one you make)
Now, having said all the above.... I have used E10 (regular) in my boat for as long as I have had it and cannot tell any difference from any other grade......
ymmv.......
