I got a used generator with a bad ( leaking ) fuel tank, my thoughts were if I could use my marine fuel tank to supply fuel to the genny ?? My only concern is that the old tank was gravity fed, the marine tanks seem to work off of the pump ball ( the plus is the marine tank is 12 gals ) ??
will this :
work with this and the tank on ground level, or is the tank still gonna have to be higher that the carbs ??
will this :
