The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
Just got a new boat, cant make out the numbers on the prop. It is an alum 4 blade. What prop is anyone using with this boat? I would be most into low to midrange use, not corcerned with top speed.
Thanks for any help
BTW it has a 5.7 motor
While a similar boat might get us a starting point;
I think you will get more help if you just tell us the prop size (possibly under the prop nut)your present max rpm and speed.your typical load and activity.
A prop shop can measure it for you.
