reeves timing question on 1985 140 looper
dragginballz
Just dropped a new powerhead on my 1985 evinrude 140 looper. Going to set initial maximum spark advance using the reeves method just to make sure its close before a final water test to zero it in. It does not state if it should be done with muffs or without. I assume with muffs, i never turn my engines over without a water supply and this is a brand new water pump and housing kit.
sutor623
Yea man anytime you spin the motor you should have the waterpump submerged.
If you have quickstart you have to disengage it for the reeves method. Make sure to set the wot timing 4 degrees lower than what the book calls
For when setting the timing with the reeves method.
sutor623
Sure thing. I also have another method that I like to use, was taught to me by a member on here, and I think it is more accurate. PM me if you are interested.
