Re: Reed replacement in Merc 150 Xri... How to?
First off, why do you think you need reeds?<br /><br />I purchased a used intake off Ebay, and spent the winter rebuilding the carbs, rejetting, and doing the reeds. Make sure you lap the reed cages on a piece of flat 1/4" glass and 400 grit wet dry paper and lots of wd-40 before you put the new reeds on.<br /><br />As to removing the intake, I havnt done that yet. You should get a manual though. Im a mechanic, so it dosent look like much to me, but there are a lot of things that have to be desconected before you start to remove the intake, and you will want to have a pad handy to draw our hose and wiring locations. If you are handy at all, you should be able to do it all in a couple of days and a couple six-packs, (one each day).
