I went down and looked at my 2001 Yamaha 150 hp HPDI longshaft outboard and noticed a red or purple liquid pooled up on the edge of the cavitation plate. The trail looked as if it was coming out of the place on the lower unit where there is that grill that you can see all the way through the lower unit. I thought maybe lower unit oil at first then gasoline then maybe even hydraulic fluid from the tilt/trim. What is this fluid and should I be worried about it or not? It doesn't look to be enough to be worried about but I just want to know what fluid is leaking out.<br /> Thanks,<br /> Ben Fredericks
