Parachute Adams
- Aug 17, 2013
- 32
Recently purchased a new Faria 7000 RPM Tachometer to replace the old busted/broken original tachometer.
I performed a preinstall to test the set up; plugged wire harness into new tach and cranked engine before fully installing into console. The tach registered power (needle moved from resting to '0') but did not register the signal from engine.
I have an Evinrude E70TLCRD (70HP, 1984).
On this motor what sends the signal to the tach? The rectifier or stator?
Thank you for the help!
