Re: Rectifier melted.... cause?
Overly simplified rectifier theory of operations.
Your rectifier contains four diodes AC, power in a wave comes in, and DC, straight steady power comes out. AC comes in from two leads one and inverted wave of the other. when the voltage is positive on the lead it travels one direction through the diodes, when negative it travels the other direction through the diodes. Since each AC lead is a continuous wave and inverted from the other, it really doesn't matter which AC lead goes where. The schematic for the rectifier is as follows:
AC comes in from the top and bottom. Pos DC out the left, and neg DC out the right.
These usually fail by one pair of diodes shorting out. Leaving only one side rectified. This is known as half-wave rectification. And, is essentially some amount of DC overlaid by a similar amount of AC. The acompanying circuitry in your regulator will throttle down DC to about a 12.5 volt level. However AC will generally pass right through. I've seen as much as 25V AC go through (plus a 10V DC offset) This will definitely begin to fry electrical elements.
Do not let this happen to you.
