i know now the 5 wire is a 35amp the 4 wire is a 10amp
Can a 35 amp reg/rec, be used on a lower amp stator?
The reason I asked is, I have a chance to get a good used 35 amp rec/reg for a good price. The only differance I seen, was the one I have, has the purple wire (5 wire), which is not used anymore on newer rec/reg as posted. So why would the wires have to be jury rigged?
35 amp regulator has heavier and different length wiring and various connectors for different engines. Make sure it is the right style also as loopers and crossflows have different bolt patterns and gaskets.
