Recovery Strap (snatch strap) I'm sold.
Bubba1235
No longer on Forums
Watched my neighbor pull a John Deere 4020 (field tractor) out of a hole / ditch this evening with his 3/4 ton pickup using a snatch strap. I was a total skeptic that a pickup was ever going to budge the tractor until I seen it pull it out. Yup, going to add it to the list of possible xmas presents I'd like.
mommicked
Re: Recovery Strap (snatch strap) I'm sold.
The best part is it's hard to damage a vehicle w the stretchy straps, unlike an unforgiving chain, when hooked to the right pull point. I've seen many 4wds yanked out of nasty mudholes w snatch straps. It might take more than one yank, but thats part of the fun!! you can also add strong rope,strap or chain to reach farther than the strap length, just lay something heavy on the line, a big canvas tarp works well, and stand back incase something breaks, as w any recovery.
raymondpickens
Yup, made a killing with them in high school and a bronco II pulling out MUCH bigger stuck trucks in the mud and at the beach.
Laddies
Banned
Never ever use a chain with a snatch strap, if it comes loose it's going thru a back window at least.
bassman284
Also don't use a snatch strap with metal hooks on the ends. I don't know if they even make those anymore, but they used to and I've seen some impressive damage done when the attachment point on one of the vehicles lets go.
rbh
snatch strap???
Is that the flat web belt 4-6 inch wide.
For removing stuck vehicles I keep about 60 feet of 1 inch power braid in the truck, almost has that bungee effect, not the hard snap of a chain.
WIMUSKY
I carry a strap with clevis's when I'm plowing snow. One, just incase I get stuck, and two, incase I come across someone else that needs help......
jeeperman
A strap with hooks is a tow strap. For dragging another vehicle down the road.
A strap with strap loops (no metal) are snatch straps.
12vMan
They're a requirement for most organized 4wd runs. I keep three 25' straps with me on the trail.
zopperman
I use em to lift OB's.
puddle jumper
Yup keep two of them under the back seat at all times. See rob you were safe the whole time we were out.
