Recommended RPMs at WOT - Merc 5.7L
Status
Not open for further replies.
rmurray
Trying to find the recommended RPMs for my 1987 Mercruiser 5.7L 260HP with Alpha One at full throttle. I'm right around 4000, but I think I should be a little higher (21' Bowrider). Thanks for the help!
180shabah
Re: Recommended RPMs at WOT - Merc 5.7L
It is either 42-4600 or 44-4800, somebody will chime in here with the exact answer. Reguardless though, 4000 is too low.
Ayuh,........
About anywhere in that neighborhood will do,.......46/ 4800 is the Sweet Spot.......
Don S
4200 to 4600 is what Service Manual #9 is showing. This manual is for the 1985-1988 5.0L and 5.7L engines.
Mjust
I have a 96 5.7L LX in a 18' open bow and have the same problem, hits 4000 and seems to hit a rev limiter. Been working with the guys on here to figure it out. I have the Alpha One Outdrive with a 1.62 Gear and a 21 Pitch prop.
getsideways
service manual for my 1996 5.7 210 horse with 2 barrel says 4200-4600. im right at 4500 in my 210 bowrider with 4 adults and 1 child. i have a ballistic 14 3/4 x 19 stainless prop.
Don S
Uhhhh, guys, he doesn't have a 1996 model, he has an 87.
rmurray
I know its not a rev limiter problem. I have two props (I think an aluminum 19 and a SS 21). The 21 is what I have on there now. With the 19, I get the same speed, but exceed 5000 RPM (working too hard). I'll have to try a 20 I guess. Can I buy a prop, try it out, and return it if it isn't right?
Don S
You don't have a rev limiter in your 87, you only have a Thunderbolt IV ignition, not the Thunderbolt V. Apples and Ornages.
Check with your local prop shop or Merc dealer for the prop trial. Usually you buy a prop. Try it, then change as needed till you get it right and don't damage the props. But you do have to buy 1 prop, and you damage it, and you own it.
rmurray
Thanks Don. You helped me twice in one day. Kudos!
badbowtie
On you'r 19p prop I would check it or have some one else check it if you are changing 1000 rpms with it I would say you have spun the hub in it. You should only change about 250 rpms per pitch.
Springchaser
I have a 20’ Larson laser with the 5.7 mercruiser and I run a 14.5 x 17 4 blade prop . I get up 55mph at 5500 rpm .
Status
