Boomyal
- Aug 16, 2003
- 12,072
Any recommendations for the above? My 'new' 302 has a set a late OEM Autolite Platimum plugs with a huge gap (probably .054) and I don't think my Pertronix II with 40K volt coil will drive them. I'd like to use them because they are basically 100k mile plugs, at least in an late model auto with a high output ignition.<br /><br />Also I would want something that would work with a tachometer. I used to run an old CD ignition (Delta Mk 10) but my replacement tach would not work with it. Maybe I'd need to get a different tach. I don't like my current one anyway. It sits at about 2000 rpm with the key off. It does seem to register correctly when the engine is running, however.
