Recoil Starter Removal on 2000 Johnson 9.9
Status
Not open for further replies.
Spooner1
Trying to remove the recoil starter on my 2000 Johnson 9.9 MN J10RSSA. Removed the 3 bolts, the easy part, but not sure how to remove the link lockout # 10 from the cam starter lockout # 22 which connects to the housing # 4 on the Johnson / Evinrude parts schematic. Any help would be appreciated.
T225Grady
I have a 2001 15HP, which I believe is the same engine. There is a plastic pin that runs through the lockout, you can squeeze the end and pull out the pin(see picture). BE CAREFUL, there is a spring that may fly out. Don't ask how I know :( . From what I read you can run the engine without it , but it is a safety device.20210521_124147.jpg
Status
