jwellcraft
- Nov 5, 2009
- 233
Can anyone advise which direction the flow should go on these check valves that are installed in the intake manifolds of the 1994 Johnson 150 loopers? So if you have your manifolds installed with the reeds cages in but no carbs on where you can see the speghetti gasket and the 6 checks valves 2 on top 2 in the middle and 2 to the bottom looking from that direction, which direction should these allow flow to go? One end seals and the other allows and these are those little brass yellowish parts that have a little round red or silver tab that moves back and forth inside and one end you just see a hole and the other has a piece of fiber looking plastic stopper that stops the little red or silver tab from coming back and sealing, thus allowing flow.
