Re: Rebuilding trailer rollers
tashasdaddy
Boy have you got that right, That trailer is in bad need of overhaul, some TLC.
Paul
The rollers don't look that bad. With his boat off the trailer you an closely inspect the rollers and make a much better assesment of the whole situation.
You will have your hands full trying to redo the whole trailer in one weekend but if you will start early, work late and be persistant you can do it.
Get all your materials lined up first. Grinder, grinding disks, Hand sand paper, wire brush, primer and paint. Then have at it.
Good luck. Post some pics when you get it all done.
Take winch, Spare and everything you can off before you start grinding and sanding. Even the tongue jack. Block the wheels and use a bottle jack or something to block it up.
