Droll
Thread starter- Joined
- Jul 30, 2003
- 514
I plan to rebuild my old V4 powerhead. <br />But what happened ?, wrist pins on port pistons got loose and really did some damage to the cylinders
, starboard pistons were still good . <br />
<br /><br />The questions to you is:<br /><br />Why did the powerhead fail? I got some theories <br />The thermostat house was repaired by the previous owner ( inserted tube )see pic<br />
<br />Would this repair restrict the water to this part of the powerhead ?<br />Upper/lower seal was worn out,wrong mixture to top/bottom cylinders ?<br />The lower mixture needle on carb was bent ( only the part outside carb? I think )<br />The cam in the distributor were destroyed, had to make a replacement ( worked fine (homemade ), but was later replace by an <br />electronic ignition from an Audi 80
)<br />To high RPM ? , 15-foot boat, prop 10 x 12 .<br />Other things? <br /><br />Other things to consider when rebuilding?<br /><br />I got new bearings / seals org. OMC<br />new gaskets, mainly org. OMC<br />New pistons /rings org. OMC<br />Block will be bored up .020<br />Replacing distributor ( used but whith new points, cond. ,rotor ,belt ) <br />New water pump (whole) ( the old one is still usable with almost new impeller , but
) <br />Rebuilding carb ( new high/low speed needles, gaskets )<br />New rod bolts , ( not yet rodbolt
but I will )<br /><br />Still missing some parts but I think I got all those hardtofind parts ,thanks to some people here + Ebay + others.<br /><br />Thanks<br />Arne Kjetil
