desertgoldhound
- Aug 8, 2006
- 41
I have just purchased a boat that has a 70hp Johnson outboard. I was told that the motor was no good. They said that piston #3 was bad. I will be picking the boat up in two weeks.
I would like to save this motor. I would like to rebuild the whole thing.
What tests would be good for identifying the problems it is having (I.E. Run a compression test)?
Can you bore the motor? What is the highest bore you would go?
Thanks in advance
Thanks in advance
