I am rebuilding a 2bbl 5,7 Merc from 1997 S/N: K156863.
It looked pretty rough and was siezed due to water intrusion caused by rusted out exhaust mainfolds, had been sitting with saltwater in it for over a month.
The engine is now in parts, allthough i have not pulled the crank and cam yet as I was waiting for a tool to pull the harmonic balancer off. The bores look decent and a will be Ok after some honing.
Now to the question:
The engine has a roller cam, plastic cam gear cover, but not Vortec heads (12 bolts holding the intake). I want to buy a rebuild kit with gaskets, bearings, pistons, Cam, lifters etc but all the kits are either Vortec (With roller cam) on Pre Vortec (with solid lifters). All marine roller cams and lifters that I have found are for Vortec engines, will a Vortec roller cam fit in block or should I just go for solid lifters/Cam and buy new pushrods?
Please give me some suggestions on what to do!
Regards
Martin
Regards
Martin
