Rebuilding 82' 25 HP Johnson.
Hopper
After investigating some silvery deposits on my sparkplug, I discovered this...<br />
<br />
<br />
<br /><br />My fear is I will rebuild this motor and not fix the problem of why this occured in the first place. I use Chevron gas and Penziol TC-W3 synthetic blend oil and measure my mix out in a ratio cup. <br />If you have any information at to why this might have happened only to the top cylinder or any tips on rebuilding this motor, I'd really appreciate the help.<br /><br />Sorry about the long post.<br /><br />Thanks for the help,<br /><br />Hopper
Backlash
Re: Rebuilding 82' 25 HP Johnson.
Hey Hopper,<br />After the rebuild, make sure the timing is right on the money. Check your manual for both the idle timing & WOT timing specs. Looks like pre-ignition problems to me. <br />Good Luck,<br />Backlash
Hopper
Thanks Backlash, I'll definately check that out!<br />Pre-ignition was my thought too.<br />One mechanic out here mentioned something called Metalization and a possible fuel delivery problem. Ever hear of that?
clanton
Check upper water tube grommet, insure water tube is clear.
Hopper
Thanks Clanton, is that behind or around the plate where the indicator stream feeds out of? I assume that the water tube that comes out of the impellor housing feeds into this plate somewhere to distribute the water. Or am I way off base?<br /><br />Thanks,<br />Hopper
Backlash
Hey again Hopper,<br />A fuel delivery problem is another possible cause.....no fuel = no lubrication = friction = overheating. Also Clanton mentioned a possible cooling problem. All worth checking. Good Luck,<br />Backlash
Hopper
Well Clanton, you were right!!!<br />I checked the upper water tube grommet and it was pinched so only 1/2 of the water could get through.<br /><br />
<br /><br />Is this pretty much all I need to look for?<br />I assume this was the problem.<br />I mean aside from making sure the timing is dead on and all carb adjustments are made when I rebuild it, should I be worried about anything else?<br /><br />Thanks so much for all your help!!!<br />Hopper
norman158
you might as well give it an impeller while you have it torn down
Hopper
Will definately do that Norman, thanks!!!
davidd267
Does that johnson have 2 carbs?? sure looks like a lean condition as if the top main jet is plugged or some kind of fuel problem
clanton
If the grommet had a groove in the center with the grommet fitting half on the tube and half off the tube, with flare on the end of tube fitting inside the groove, push the grommet on far enough to just below the flare checking fit in block and waterpump. How do you do the great photos?
Hopper
Hey Blue Water,<br />It only has one carb. Not sure what it looks like behind the carb. Haven't torn into it that deep yet...<br /><br />Hey Clanton,<br />The pictures I take on my digital camera, then move them to my PC, then move them to a website. If you click on the "image" button below the Instant UBB Code you just then input the internet address to your pics and they come right in.<br /><br />Well it will be a few months before this motor takes to the water again. With ******mas just around the corner the wife might not understand me spending $300 - $500 to get my baby going again... But that gromet will be replaced!<br /><br />I sure appreciate all the help I've received here. <br /><br />Thank you all!!!<br /><br />Hopper
