Howdy all,
I picked up a 200HP 1994 outboard that was winterised a number of years ago. I got it to start and run, decided to rebuild the carbs for PM and to make sure everything is clean.
Took them off and one apart today. There are a lot more threaded brass inserts to unscrew than other (OMC) carbs I have worked on, ALSO, there are adjustable needles!
The Merc service manual says to count the number of turns they are at now and install new ones to that same setting. For some reason each carb kit I have came with 4 needles?
Any further adjustment after install? A friend mentioned syncing the carbs, I have no idea how to do that.
Thanks,
John
Thanks,
John
