- May 19, 2001
- 26,049
Kind of semi-off topic... <br /><br />I have a 5 x 8 trailer I picked up and I want to use it to haul my 2 ATV's. The deck of the trailer is 3/4 plywood that is in dire need of replacement (the top layer is "shedding" and falling apart ... but is still sound) and I am looking for suggestions on what to use. The trailer is rated at 2000 and the two atv's together add up to 1250 loaded with gear.<br /><br />There is an existing steel frame (with stake pockets) around the outside.<br /><br />Should I go with plywood? Steel sheeting? I have not found a source of aluminum decking close to home.<br /><br />An alterantive is to seal the plywood and just cover it with a sheet of 3/8.<br /><br />The atv's will be side loaded and carried side by side (and very close together due to the 8' length).<br /><br />It's a project that is going to take lights, tires, bearings and I will also need to build removable side ramps.<br /><br />Bob
