Your support and response to my problem regarding a<br />blown/detonated piston on my 140 85 rude has left me so much wiser regarding this subject and I'm very,very, grateful to have such a great bunch of guys to educate us 'greenies'<br />Yes- I've done my homework and I need your advice.<br />Qestion-The cost of rebuilding compared to replacing.<br />Naturally, I can't afford a new engine but I found<br />out the electonics, throttle assembly, etc. on my boat would be adaptable to any OMC up to 1994.<br />The upside- a newer engine.<br />The downside- I wouldn't know the history of the engine plus in 99% of the cases, I wouldn't be able to pull the necessary tests (compression,etc.) to see if it'll be worth the money. Don't want a repeat performance down the road.<br />The vast majority of people I've asked advised me to replace and bore the ENTIRE engine- not just <br />one cylinder/piston because the vast difference in compression from the new cylinder in opposed to the <br />original equipment. Yes - it ain't cheap but I need to go in the correct direction. What do you pros out there have to say. As always, much thanks for your help
