rebuild carbs
bayclammer
I have a 1972 Johnson and it has three carbs Can any one give me step by step instructions on how to rebuild them
D
DJ
Guest
Re: rebuild carbs
That would take more room than available here.<br /><br />I would suggest you pick up a manual. They're availble right here on i-boats and most are under $30.00. They're all over e-bay too.<br /><br />It will be the best money you ever spent.
Waterbugtoo
Re: rebuild carbs
Simple. Take em apart, vat em, put em back together with new kits. Get a manual to help you along.<br /><br />
bayclammer
Re: rebuild carbs
I have a manaul but it does not show you how to take the carb apart or even show you houw it just shows you what parts make up the carb
rickdb1boat
Re: rebuild carbs
What manual do you have? Most have a detailed description on how to disassemble the Carbs.
mellowyellow
Re: rebuild carbs
perfect reply as always Bear ;) <br />if anyone deserves the "Admiral" rank for 1K,<br />you do!<br />warm regards,<br />M.Y.
Bear
Re: rebuild carbs
Thank you very much mellowyellow. <br /> :) <br /> :)
bayclammer
Re: rebuild carbs
Every one thank you for your help it has been really helpful and I thank you a lot
