Reasonable L.I N.Y rude mech wanted
crazy charlie
I need to rebuild the carbs on my 84 115 hp eninrude.Anyone interested in making a few bucks before I tackle it myself???? I am told it is not too difficult to do. Charlie
Luna Sea
Re: Reasonable L.I N.Y rude mech wanted
Charlie,<br /><br />Before someone else suggests buying a manual, I'd like to suggest.....<br /><br />I paid someone big bucks to rebuild my carbs, I could see a gasket down the throat of one of them that wasn't set right, brought it back, still have problems........ May be worth doing yourself, only you will take the time to make sure the job is done 100 percent. Plenty of good info/help here.<br /><br />And don't forget to do some "searches" on the subject! :D
crazy charlie
Thanks for the opinion Luna Sea,that seems to be the way I am headed. charlie
braindead0
It would be useful if you could find somebody that's done this before to 'lean on' the first time through.<br /><br />But, a good manual should cover all the bases.. read it carefully and follow the instructions and you should be okay.
The Marine Doctor
Crazy...you will find it very easy. Just leave one intact while the other is disassembled. It will be your guide if you need one.<br /><br />TMD
