Jimmy H.
- May 15, 2012
- 220
Hi, I've just recently started my motor up for the first time in the boat with muffs. Was very shaky while it was warming up. I did find that the rear mount bolts were snugged but not torqued. I torqued them to 35 lbs/ft per the manual. It seemed better. I also noticed part of the bell housing was in contact with the deck so I chiseled some away to give some clearance thinking it was transferring vibration to the deck. I started it today and it is worse! It wobbles from side to side at idle, at 1000-1200 rpm is an extreme wobble (like the motor is going to snap off the rear mounts, at 1600+ rpm is very smooth. I know these motors are shaky but the worst part is so bad it cant be right.
I pry slightly with a screw driver between the deck and the motor and there is easy movement at the rear mounts.
The rear mounts I assume are worn and I will lift the motor and replace them if I know this is 99% of the issue. The mounts appear to be low in the motor housing and looking at it from the bottom there is a gap above the fiber washer which doesn't seem right. That is where the play comes from and it rocks like a son of a ...... gun.
Here is a shot from above. The mount seems low to me??
Here is a shot from below and you can see the gap above the fiber washer. Is this normal looking?
Thanks to anyone that can share some knowledge.
James
James
