Hello,
I have been searching the net for some time looking for information pertaining to a stator upgrade for my boat. I've been dealing with the issue of dwindling batteries while out for the day. My boat has a lot of heavy draws on it, most notably, a large sound system. I didn't realize that I'd be facing this issue after choosing to purchase an outboard...but, here I am...
The boat has stock power trim, so it should be equipped with a 9A stator (OE part # 583536, 583340, 763767) and it just doesn't quite keep up with my uses depending on how much floating I plan on doing that day. I'm looking to get in the realm of 15 - 35 amps if at all possible. Not sure if this has been done on this motor, and I don't quite know where to start.
I know I would have to upgrade the rectifier and potentially wiring as well, which is fine. I just don't know if there is any sort of standards for stator physical sizing, spacing, hole location, etc...there are so many different ones that I find on many sites.
I have already installed a Blue Sea Systems battery switch and charging relay that allows 2 batteries to be charged while saving one for starting only. This makes the best of a bad situation, but I'd rather fix it right.
Any insight into this issue would be greatly appreciated, this is something I REALLY want to do!
Thanks!
Thanks!
