Re-use exhaust housing gaskets?
Adalrik
I just finished re-sealing a lower unit only to take it out on a first run to find that I should have inspected the shift dog a bit closer. In best practice, the exhaust housing gaskets should probably be replaced when removing again but; has anyone had experience in re-using them? It’s only 20$ for the pair but 20$ is 20$.
F_R
Which specific gaskets? Picture or part numbers?
If it is 305312 then I would re-use it.-------That gasket does not do much of anything anyway.
Well----You doubt the advice here.------But look at the 1968 model 85 HP and 65 HP.------Essentially the same motors as you have and the gasket is not shown on them.----Not even needed !!!
Adalrik
Im not doubting the advice; I simply just like to know the reasoning behind any advice.
F_R
Not needed because anything that might seep out there was headed back to the sea anyway. If it makes you feel any better, just use a bit of gasket sealer on the joint.
