CaptainKev
- Feb 3, 2009
- 107
Re:Trim Gauge & Sensor.
I have a 2400 with Volvo 5.7 GI and a Duo-prop stern drive. I would like to have the trim gauge working without having to turn the ignition to start/run. In other words........I want the gauge to work any time the drive can be moved. I'm not sure if this is a common issue, or just Regal, but I'm very uncomfortable knowing that the drive can be moved without any indication of the position. I've gone through my owners manuals for both the boat and the stern drive, but neither show the circuits that would be involved. Obviously, the trim gauge power is supplied through the gauge cluster harness, but what I don't know is does the trim sender on the drive get the power from the gauge, or someplace else. I'm not concerned with battery drain because the only time the battery switch gets turned on is when I do shore checks, or right before I launch. Any help, or information would be appreciated.
Kev.
Kev.
