JustABitAskew
- Oct 17, 2020
- 3
They make oversized screw snaps, that would be my fist choice
Fill the hole with a high grade marine epoxy and then redrill it. And install a new snap.
First Clean the hole up first with a slightly larger drill bit then chamfer the top with a 3/8” bit ran in reverse just enough to give the epoxy a little extra area to Adhere to And to clean up som of that cracking around the hole.
stock snaps have #8 screws. the over-sized have #10. you can also get the snaps that do not have the included screw and then thru-bolt it.Oooh! Simple. And worth a try! Thanks!
