BarbeeLakeMan
- Nov 10, 2013
- 1
Re: outdrive will drop but has problems coming up
Hello Fellow OMC owners. I am new to this forum so I didn't know ho to start a new discussion so I will build off this one. I have a 1987 OMC 4.3 liter with a Cobra outdrive and have a problem with the trim coming up. It goes down perfectly fine but up is a different story. At the start of last season, before it went into the water I had the same problem but when I put it in the water it worked. I used it all year without a problem. Took it out this weekend to winterize it and again the up will not work. If I continue to push the up buttom on the shift handle I hear a clicking. If I push it enough times it will work but that is probably 1 in 30 pushes. I cleaned all connections, opened up shift handle and the wires look good. Does anyone know what can be the problem? If the selenoid is bad will it still click? Any help would be great.
