re: KROSEMOND - leaking oil
I'd really like to know how you made out with your problem of oil leaking from beneath the cowl and down the shaft. I have a 1983 Johnson 150 that just started the EXACT same problem after the dealer did some "carburetor work" during commissioning. Another mechanic told me that it is a worn or squished "base gasket" that is leaking, but your thread sounded so similar to my situation. My motor is running great so it's hard to believe that all 6 cyl. may not be firing. But if you say so.. I hope that you got your problem solved and can maybe help me out. Thanks.
