Re-jetting older Johnson for modern fuel
jimibee
OK I hope we have an OMC guru out there. I have a 1979 Johnson 235 HP outboard that I just rebuilt. It runs great, but before I put it under load I was curious if there are factory recommendations for enlarging the low and Hi speed jets for modern fuel,( up to 10% alcohol)? I have installed fiberglass reeds,( which require opening the stock Low speed (.032") jets .002" to .034 total. Is there a need to open them up more for modern gas? I DO NOT use the reformulated fuel here in SE WI.
JB
Re: Re-jetting older Johnson for modern fuel
I agree with S&R, Jimibee.<br /><br />Avoid alcohol enhanced fuel if at all possible and don't mess with your jets further.<br /><br />There are too many parts in a '79 engine package that turn to goo when exposed to alcohol.<br /><br />Whatever fuel you use, the jets only determine the fuel/air mix and 10% alcohol still requires about 14:1 ratio, same as 100% gasoline.<br /><br />Good luck. :)
jimibee
Thanks. I just wanted to make sure it didn't lean out.
