Re-fill fluids - Where / What ?
roryhinds
I'm new to this forum. Hi :) I have a Sea Ray Sundancer 250 with Merc 5.7 and Bravo II leg.
I need to refill the fluids. I need coolant in my closest cooling system (Fresh water) and want to make sure I'm putting it in the right place as I'm much better with cameras than I am with motors.
Attached are some photos.
Could someone please let me know what each is and what fluid I should put in.
GA_Boater
Welcome aboard.
#1 - That's the place, it's the heat exchanger. Water/antifreeze mix
#2 - Right, the coolant overflow. Water/antifreeze mix up to the hot or coldline
#3 - That's the lower unit lube reservoir. Lower unit lube.
#4 - Power steering pump and reservoir. Power steering fluid.
#5 - Tilt/trim pump and reservoir. Either 30W oil or ATF, Automatic transmission fluid.
If you have an owner's manual all this should be covered.
achris
More fish than mountain goat
Welcome aboard.
:eek: :eek:
I only see 4 numbers, and #1 is NOT water/AF... It's the power steering reservoir, Power steering fluid or ATF...
#4 is Trim/tilt pump, uses the same as the power steering reservoir...
Chris........
tpenfield
#1 = Power steering fluid
#2 = Coolant
#3 = Outdrive gear oil
#4 = Outdrive trim Fluid (usually 30 wt motor oil)
