Hi,<br />About three weeks ago I wrote in about a reoccouring condition "temperature climbing up at idle" and after a few quick revs the temp would come down and remain there, I have been going over this in my head endlessly and thought back to when I first bought the boat, I decided to change the thermostat and was given a 140* automotive looking t-stat. The one I removed was a heavy looking roung bodied 143 brass unit. Is there any difference in these two t-stats and should I change it out.<br />Also will there be any benefit or harm to gutting the present t-stat and using it as a restrictor.<br />My set-up is 5.7 260 stock, open cooling system, 1987 alpha 1 impeller in the drive which is new.<br />there is no over heat condition at any rpm except the temp creeps at idle idle when first started.<br />AL
