raw water pump question
wendellbee
My port raw water pump seized up over the winter.I have a sherwood P103. the replacement for this discontinued pump is a P105 but the mounting holes do not line up .Is there any pump out there that will have the flange mounting holes in the 12,3,6,9 o'clock positions? i have 1990 OMC/Ford 460's inboards. I replaced my starboard pump last year with a johnson but had to drill an extra hole in the flange, ream out one of the existing smaller holes, and use spacers to clear the crank bolt in order to mount the pump.
Ayuh,..... Sounds like it's time for a repeat performance,.....
Havin' done it before, it oughta be a breeze, 'n the pumps will match, as they should,....
