When i put my boat on the trailer last, right before i shut it down i checked to see how the water was flowing out of my through hull exhaust, which it was normally. However, when i got home and hooked up the ear muffs to flush the motor, it wouldn't run any water through the motor.... Took a look at the impeller but it was in fine shape. (I had just replaced it the week before i used the boat)
I took the hose from the raw water pump to the thermostat housing off of the thermo housing, connected the hose and backflushed it, water came out the drive at what looked to be an ok rate. Reconnected everything and fired it up, no water flow.
I then disconnected the line from the transom to the raw water pump and hooked up an extension so it could pick up water from a trash can outside the boat, fired it up and water flowed through the motor normally. So it seems the problem is definitely in the transom/outdrive... Anybody have any ideas?
Nate
Nate
