Magnus Wallner
- Jul 4, 2012
- 32
Hi.
I have a 1992 Merc 5,7 in my 1976 Sea Ray 220. I've had a leak somewhere, been taking in sea water but only (or perhaps mostly is a better word) when running the boat.
Yesterday, it's been getting worse, I found that there is a little hole in the hose between the raw water pump and oil cooler. The hose has been rubbing on the fuselage and finally it rubbed through. It's not leaking to a visible extent with the engine off but with increasing rpm it goes from a trickle to a high pressure stream (at least I know much raw water pump is working...).
I'm about to replace the hose but here's the problem. I would like to close the raw water intake valve (it's a brass body ball valve by the looks of it) but I haven't operated it (had the boat a few months) and I've been speaking to the PO and he never touched it either (had the boat for like 5 years). Is it possible to replace the hose without closing the valve, ie how much water will move flow through the pump? I suspect that the valve might start to leak as well if I start messing with it.
Boat's been run in brackish and sweet water (about 0,7 per cent salt content) so not real sea water for as many years as any can remember.
What do you think - replace hose without closing the valve or take my chances and close it first?
